LabWindows/CVI
Comparing 2 jpeg using Labwindows
Hi guys,
Is there a way of comparing 2 JPG files and determine if tey are different?
(4,011 Views)
As I understand it there is an option within CVI that allows customers to compare the text of source files against one another using the edit » Diff command.  Other than that, there is an active X call to the CVI_AppDiffTextFiles function, which also compares the contents of different text files.  I am currently unaware as to the ability to compare .jpg contents.  I will check my resources to verify that this is true and get back with you shortly.
Shawn S. | NIC
Instrument Driver/IVI PSE
(3,982 Views)
Thanks Shawn, I think someone said something in the forum but in LabView. Let me know if you come across something.
Javier
(3,977 Views)
Accepted by topic author JHernan
Hello again,
I looked into this further this morning.  If you open the LabWindows CVI Help, and search for "jpg". You get a handful of results.  You will want to click on the article titled, "Using Bitmap Objects".  The Bitmap is a two-dimensional grid of pixels that represents an image, and a bitmap can be created from multiple image types (including .jgp).  You will want to create a bitmap for each .jpg file and programmatically trace through each value within the grid, subtracting each bitmap value from its corresponding value and storing the result into a new result array.  Then just check the new bitmap where the results of the subtraction are stored for any non-zero values to determine if the files match and to what degree.
Try that and let me know how it goes!
Shawn S. | NIC
(3,973 Views)
Sounds good, I will get back to you.
Javier
(3,970 Views)
