LabWindows/CVI
Compile MySQL C API with LabWindows/cvi 2009
Due to must program a 64-bit application with cvi, which need the database support, so the database toolkit of labwindows/cvi cannot be reused, because it is just for 32-bit application. My application using MySQL 5.1 as the data access module, thus look for  using its C APIs to design the database access interface. When compiling the code that includes the MySQL's head file, cvi throws an error: The  include file "sys/types.h" was not found. I know this include style  is in UNIX or Linux system, so I can not find the related include file. If this means that cvi's compiler does not support the MySQL C API's compiling?
David
Message 1 of 9
(6,302 Views)
David,
The latest version of the CVI SQL toolkit does have 64-bit support.
Luis
Message 2 of 9
(6,283 Views)
Thank you, Luis. By the way, does the labwindows/cvi internet toolkit have a 64-bit edition?
David
Message 3 of 9
(6,249 Views)
David,
The intenet toolkit was discontinued a long time ago (around 2004 or so). At that time, most of the functionality of the toolkit was incorporated into CVI itself (FDS edition), becoming the Internet Library. The toolkit then ceased to exist as a separate product.
As of CVI 2009, you should be able to use Internet Library functions in 64-bit applications.
Luis
Message 4 of 9
(6,239 Views)
Hi Luis,
Maybe the continues topic is not relateted the subject, but I still want to enquire that for the internet tools. To the old internet toolkit, I can export panel to a web browser using INET_PanelToJPEG(), however in the cvi 2009 internet functions, I can never find such a function, is there a substitution like the  INET_PanelToJPEG() function in cvi 2009?
David
Message 5 of 9
(6,225 Views)
Hi David,
  Maybe you can implement this application with .NET library since there is no related function to implement this directly in LabWindows/CVI 2009.
Ben
Message 6 of 9
(6,216 Views)
.NET? um, I think that is far off to me. Thanks.
David
Message 7 of 9
(6,197 Views)
David,
I don't remember exactly what INET_PanelToJPEG did, but from the name, it simply sounds as if it created a snapshot of a panel as a JPEG image. If that's the case, you can still do that in CVI, using the following UI library functions:
1. GetPanelDisplayBitmap (or GetScaledPanelDisplayBitmap)
2. SaveBitmapToJPEGFile
3. DiscardBitmap
Luis
Message 8 of 9
(6,180 Views)
Hi Luis,
Thank you for your reply. I'll try to it. It maybe need to design a CGI by myself.
David
Message 9 of 9
(6,161 Views)
