LabWindows/CVI
Compiling toolbox.c from CVI 8.1 using VS C++
I have a MS VC++ project using toolbox.c from LabWindows 8.0. The project compile and link fine. Switching to LabWindows 8.1, the project does not compile. I get the following error:
c:\Program Files\National Instruments\CVI81\toolslib\toolbox\toolbox.c(1064) : error C2065: 'COINIT_APARTMENTTHREADED' : undeclared identifier
Switching back to 8.0 files, the project then compile fine...
I need to switch to 8.1 for the new TDM files capabilities...
Yannick Willener
(3,575 Views)
You probably need to add _NI_mswin32_ to the C compiler preprocessor definitions in your VC project settings.
Martin
Certified CVI Developer
(3,561 Views)
It works...
Yannick Willener
(3,551 Views)
