LabWindows/CVI
Complete Desktop Screen capture ?
Another thing I didn't find the way to implement, is to capture a bitmap
of the complete desktop screen (as it appears to the operator). If I say
"complete" it is because we often have two monitors.
Does anyone knows about this ?
--Fred.
(3,938 Views)
Hi Fred,
Have you tried using "ALT + Print Scrn"? That should place a bitmap of the desktop into Window's clipboard.
Then you can paste the bitmap in Paint or something along those lines.
Good Luck,
Ted F.
(3,938 Views)
Fred,
I think to be able to capture a complete image of the desktop, or what is seen on your two monitors, you will need to use Windows SDK funcitons. For this, you can go to http://msdn.microsoft.com/library/default.asp
We also sell a toolkit called the internet connectivity toolkit which has functions that take a panel, and store it to a .jpeg which can then be converted to bitmap. Those functions are:
INET_PanelToJPEG (, "", 0, 80);
INET_JPEGToBitmap ("", , , 0);
Thank you very much for using the Discussion Forum, the best medium for finding answers to you issues.
Daniel McChane
Application Engineer
(3,938 Views)
Yes, I tried this using the Windows SDK, but didn't succeed. I'm not so
good with this kit.
By the way, is there a way to link a BITMAP or HBITMAP cretaed with the
SDK with the bitmap handle CVI uses?
DanielMcchane a écrit :
> Fred,
> Daniel McChane
> National Instruments
F. Maillet - Sodatec Toulouse
Responsable Qualité Projets
(3,938 Views)
