LabWindows/CVI
Complex 3D drawing
I have an application that should be able to plot complex 3D objects. These objects are provides as a set of triangles.
I would like to draw this objects using 3D graph ActiveX shipped in CVI.
The plotting function in 3D graph are rather dedicated to plot 4 edge planes (as far as I can understand).
Has anyone an idea the best way to go for ploting a set of triangles?
Thank you.
(3,423 Views)
I am not used to programming in 3D but I would advise you to use OpenGL which is really powerful. You can find a lot of examples in CVI with the example finder : Help > Find Examples > 3D > ogldemo.
(3,409 Views)
