LabWindows/CVI
Concatenate arrays?
what function i must use to concatenate two 'double' arrays?
(3,655 Views)
CVI does not have any functions for that, but its something you can do really easily.
One =(double*) calloc (10, sizeof(double));
for(panelHandle =0; panelHandle<10;panelHandle++)
One[panelHandle]=panelHandle;
Two =(double*) calloc (10, sizeof(double));
Two[panelHandle]=20*panelHandle;
One =(double*) realloc (One, 20*sizeof(double)); //realloc the memory for the first array so it can accomodate the array we will concatenate.
memcpy (&One[10], Two, 10*sizeof(double)); //do a block copy of the second array into the first array
remember to free the memory after you're done using it.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,655 Views)
thanks for answering me,
i`m using CVI 5.5 i don`t think it has 'sizeof' function.
another thing,One and two are my double arrays right?
for example if I already have two full double arrays Data[200] and Array[200],should it look like that?
Data =(double*) calloc (200, sizeof(double));
for(panelHandle =0; panelHandle<200;panelHandle++)
Data[panelHandle]=panelHandle;
Array =(double*) calloc (200, sizeof(double));
Array[panelHandle]=400*panelHandle;
Data =(double*) realloc (One, 400*sizeof(double)); memcpy (&Data[200], Array, 200*sizeof(double));
so Data now includes the initial 'Data' and 'Array'?
(3,655 Views)
yes, One and Two are defined as follows
double *One=NULL;
double *Two=NULL;
Sorry, should have added that.
Im pretty sure CVI 5.5 has the sizeof function. It returns the number of bytes associated with a datatype.
You will need to dynamically allocate an array, not used a fixed size array like Data[200]. You cannot resize at runtime a fixed size array.
By defining pointers to arrays instead of a fixed size array, I can resize the memory allocated for the array however I like,allowing me to concatenate an array by changing its size.
Bilal
Bilal Durrani
NI
(3,655 Views)
ok , now it`s more clear to me.
just one more thing, how to assign a variable into the dynamic array,i mean like I did with fixed size arrays:
for(i=0;i<100;i++)
Data[i]=x;
thanks alot!
Ken
(3,655 Views)
the dynamic array works in the same way as the static array. Just use a for loop with a indexer like you showed in your post.
Bilal
Bilal Durrani
NI
(3,655 Views)
