LabWindows/CVI
Configuring a NI6509 in MAX
I am configuring a NI6509 and not sure how to remove a latching problem on the input.  Power up state is set to Tristate which I thougt was correct.  However, in CVI when i monitor an input that is High I recieve a correct High response.  When i make that input Low  and monitor I recieve an incorrect High response.  If I then reset the card in MAX and run the function I recieve the correct Low response.
Is there any way to stop this latching effect in MAX?
(4,491 Views)
The test panel works in MAX, so it must be the CVI environment set up ..may be mx version..not sure
(4,485 Views)
The driver that I was using worked within cvi 8 and cvi 2010.
Currently, In order to for the driver to work under CVI2012 I have had to include DAQmxResetDevice ("Dev"); to reset the NI6509 before an input change can be read.  Is there a change in CVI2012 that requires this?
(4,476 Views)
Hi there,
Are you still experiencing the problem?
Are you using a PCI or PXI NI 6509?
What version are your drivers?
The latest I can find are:
https://www.ni.com/en-us/support/model.pci-6509.html
https://www.ni.com/en-us/support/model.pxi-6509.html
Is tristate what you want? This means the output will have High, Low and Float states.
I hope this helps.
Tim, CLD, CTD
National Instruments (UK & Ireland)
________________________________________________
"No problem is insoluble in all conceivable circumstances"
(4,375 Views)
