LabWindows/CVI
Connect dual screens to NI PXIe-1085
Hi all
Is it possible to connect dual screens to NI PXIe-1085.The PXIe-1085 has one display port(DP).
(3,672 Views)
Hi Sattam,
The PXIe-1085 is a chassis that will house a controller (which I imagine you are asking the question about), do you happen to know the controller?
http://www.ni.com/en-gb/support/model.pxie-1085.html
Kind Regards,
Matthew Fergusson
Applications Engineering UK
(3,642 Views)
Hi
My NI PXIe-1085 has NI PXIe-8880 controller.
Sattam
(3,605 Views)
Hi Sattam,
I believe this support article would help you with this.
Dual Monitors with the DVI Connection on Embedded PXI Controllers and Industrial Controllers: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019M9qSAE
Kindest Regards,
(3,591 Views)
Thanks but the article  discus controller with DVI-I Connector and my controller has Display port (DP).
Thanks for your help
Sattam
(3,566 Views)
Hi Sattam,
The following article outlines that you can support dual monitors:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019O7SSAU
Kind Regards,
Matt Fergusson
(3,547 Views)
Thanks for your help.
Sattam
(3,538 Views)
