LabWindows/CVI
Connect to INTERBASE 7.5
Hi.
(Sorry for my English )
I want to connect to an INTERBASE Database with Labwindows/CVI 7.1.1 .
I suppose that I must use the SQL TOOLKIT and an ODBC Driver.
Does the SQL ToolKit provides an ODBC Driver for all Databases or Borland must provides it ?
I read that Database access through SQL Toolkit and ODBC Driver doesn't compatible with DATE, TIME; TIMESTAMP ... types ?
It's True ?
What's the mean to read DATE, TIME, TIMESTAMP types from à Database ?
Thanks for your answers !
(3,918 Views)
The SQL Toolkit has some basic drivers included, but not specialised databases.
Download the Interbase ODBC Driver and install on your PC: http://www.easysoft.com/products/data_access/odbc_interbase_driver/ after subscribing and paying or try the open source equivalent: http://www.ibphoenix.com/main.nfs?a=ibphoenix&page=ibp_60_odbc
Then create a new connect string for SQL Toolkit. http://www.jattie.co.uk/software/cvi/help/sqlstring.htm
and use the SQL Toolit to connect to your database. Thete's lots of samples after that, the difficult part is connecting successfully.
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(3,898 Views)
Thank you for your response.
I had effectively try the SQL ToolKit with Firebird Database and Firebird ODBC Driver.
It works fine.
Now I want to try different way to improve performance.
(3,889 Views)
