LabWindows/CVI
ConnectToTCPServer function - long timeout slows down system
Group,
I am working on an application that utilizes cellular modems.  They have an IP address just like any Ethernet device, except the IP is a static IP on the Internet.  It can be PINGED from the Cmd Line, just like any device.
However, the round trip on a ping may be 4-5 seconds, instead of milliseconds for a wired device, due to the complexity and speed of the cell network.
I use ConnectToTCPServer() to connect to my remote device, but use a long TCP_TIMEOUT (15-30 seconds) value to allow the modem to respond.  This slows down the system, and no other events will be processed during this time.  I have tried calling the ConnectToTCPServer() routine in a deferred callback, but same behavior.
To disconnect, I use DisconnectFromTCPServer().  This command responds very quickly, and I see the disconnect on the modem side.
Since cell modems periodically lose their connection, due to tower changes, etc, I have to reconnect on a 10-15 minute basis.  When the modem loses connection, I do get the TCP_DISCONNECT callback, and respond accordingly.
Any suggestions would be appreciated.
Regards, David Eaton
(3,459 Views)
How about having a separate thread to manage the connection/disconnection processes? That way if they take a long time it needn't tie up the rest of your application.
JR
(3,455 Views)
