LabWindows/CVI
ConnectToTCPServer is not returning an error
I'm using the ConnectToTCPServer function to try to connect to a TCP server, but when I change the port to something invalid, the function does not return an error. How can I poll the connection to determine whether I'm connected in a gracefull manner?
(4,659 Views)
Hi Steve_Block,
Just to clarify, the integer returned by ConnectToTCPServer is always a 0, even if you are supplying an invalid port number?
Tom D.
Staff Software Engineer
NI
(4,631 Views)
So how do I know the port is valid and the connection was successful?
(4,619 Views)
Hi Steve_Block,
ConnectToTCPServer should return a 0 if the port is valid and the connection was successful. Do you mean that the function is returning a 0 even if you are supplying it with a port number which you expect to be invalid?
What is the intended use of your application, and what port numbers are you using to test the function? After calling the function, assuming a connection is established, are you able to read from the server using ClientTCPRead?
Tom D.
NI
(4,579 Views)
