LabWindows/CVI
ConnectToTCPServer
Could someone help?
Why am I getting a library function error
if (ConnectToTCPServer (&g_hconversation, portNum, serverHostName, clientTCP, NULL, 5000) <0
     return 0;
portNum is 5000
serverHostName is 192.168.2.3  and I can ping it.
my clientTCP function is:
int clientTCP (unsigned handle, int event, int error, void *callbackData)
    char receiveBuf[256] = {0};
    int  dataSize         = sizeof(receiveBuf)-1;
 char lineBuf[130];
    switch (event)
        case TCP_DATAREADY:
#if 0
            if ((dataSize = ClientTCPRead (g_hconversation, receiveBuf, dataSize, 1000)) < 0)
    return -1;
   printf("TCP_DATAREADY received: %s\n",receiveBuf);
#endif
            break;
        case TCP_DISCONNECT:
   if(error)
    sprintf(lineBuf,"TCP_DISCONNECT received due to error= %d\n", error);
    PRINT_DBG(lineBuf);
       g_hconversation = INVALID_TCP_HANDLE;
   else
    PRINT_DBG("TCP_DISCONNECT received from TcpServer\n");
            break;
        default:
         printf("default received\n");
         break;
    return 0;
(3,797 Views)
Hello agyna,
which error are you receiving and where? Does it happens every time you run the code?
(3,786 Views)
Sorry, looks like the problem is resolved.
Thanks.
(3,783 Views)
