LabWindows/CVI
Connecting to a Microsoft (MS) Access Database in LabWindows
I tried getting my program to conform to what the sample program did.  It looks like the code was copied from that sample from the beginning.  I made a couple changes anyway, and I still have the same problem.  I may try opening a new project and slowly rebuilding everything from the database connection up.  That seems to be my only choice right now.
Thanks for the help.
Sorry! I didn't realize what you were asking earlier about which toolkit was used before.  I don't know the answer to that.  I thought the toolkit was installed with labwindows that long ago.  Should I have installed something else?  (I also have cvi 4.0 on cd that I've tried, but no toolkit cd for it).
Message Edited by MES on 02-10-2006 07:44 AM
Message 11 of 14
(1,919 Views)
found it 🙂    sql toolkit version 1.1 originally.   I'm trying to use 2.0 in my new project with cvi 7.0
Message 12 of 14
(1,910 Views)
Fixed my problem Smiley Very Happy
Starting from the sample, I noticed that the old project had included cvi_db.lib, but it was pointing to an old copy that didn't work.  I replaced the file to point to the new sql toolkit version I'd installed, and it connects to the database.
Message 13 of 14
(1,908 Views)
I have installed Windows XP and it works fine.
http://www.cimaware.com
Message 14 of 14
(1,095 Views)
