LabWindows/CVI
ContGen-IntClk - DoneCallback
I am following this example code, ContGen-IntClk.c.
#include <NIDAQmx.h>
#include <stdio.h>
#include <math.h>
#define     DAQmxErrChk (functionCall)      if( DAQmxFailed(error = (functionCall)) ) goto Error; else
#define     PI                              3.1415926535
#define     DAQmxFailed(error)              ((error)<0)
int32 CVICALLBACK DoneCallback (TaskHandle taskHandle, int32 status, void *callbackData);
int main(void)
    int32           error               = 0;
    TaskHandle      taskHandle          = 0;
    float64         data        [1000];
    char            errBuff     [2048]  = {'\0'};
    int             i                   = 0;
    for (; i < 1000; i++)       data [i] = 9.95 * sin( (double) i * 2.0 * PI / 1000.0);
    // DAQmx Configure Code
    DAQmxErrChk (DAQmxCreateTask            ("",&taskHandle)                                                    );
    DAQmxErrChk (DAQmxCreateAOVoltageChan   (taskHandle,"Dev1/ao0","",-10.0,10.0,DAQmx_Val_Volts,NULL)          );
    DAQmxErrChk (DAQmxCfgSampClkTiming      (taskHandle,"",1000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000)    );
    DAQmxErrChk (DAQmxRegisterDoneEvent     (taskHandle,0,DoneCallback,NULL)                                    );
    // DAQmx Write Code
    DAQmxErrChk (DAQmxWriteAnalogF64        (taskHandle,1000,0,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL)    );
    // DAQmx Start Code
    DAQmxErrChk (DAQmxStartTask(taskHandle));
    printf      ("Generating voltage continuously. Press Enter to interrupt\n");
    getchar     ();
    Error:
    if ( DAQmxFailed (error) )
    DAQmxGetExtendedErrorInfo (errBuff,2048);
    if ( taskHandle != 0 )
        // DAQmx Stop Code
        DAQmxStopTask   (taskHandle);
        DAQmxClearTask  (taskHandle);
    if ( DAQmxFailed(error) )
    printf  ("DAQmx Error: %s\n",errBuff);
    printf  ("End of program, press Enter key to quit\n");
    getchar ();
    return 0;
    int32   error           = 0;
    // Check to see if an error stopped the task.
    DAQmxErrChk (status);
    Error:
    if( DAQmxFailed (error) )
        printf                      ("DAQmx Error: %s\n", errBuff);
    return 0;
I would like to ask what generates the call to DoneCallback() function.  Thanks.
Message 1 of 17
(7,941 Views)
Accepted by topic author hn_sofec
That's easy to find out yourself Smiley Wink
Search the code for this function name and you will see that this callback is due to DAQmxRegisterDoneEvent, so this callback function will be executed when the acquisition task stops.
Message 2 of 17
(7,938 Views)
how did I miss that?
Message 3 of 17
(7,934 Views)
by the way, I do not see the arguments passed into this callback function.  how does it get its arguments then?
Message 4 of 17
(7,931 Views)
I already provided the link to the help of this function... Smiley Wink: The last argument of DAQmxRegisterDoneEvent () is the callback data, in this case the NULL pointer
Message 5 of 17
(7,923 Views)
Sorry for the confusion, DAQmxRegisterDoneEvent() calls DoneCallback(). However, as you can see:
DoneCallback() does not come with any argument or parentheses.  So I wonder where they went.
Message 6 of 17
(7,917 Views)
ah, I see. This is because the type of callback function (int32 CVICALLBACK Callback (TaskHandle taskHandle, int32 status, void *callbackData)) is well defined, so only a pointer to the function is needed.
Message 7 of 17
(7,915 Views)
I do not quite get how that works.  do you not have to have all arguments when calling a function?  otherwise, where does it get all the arguments from, when called?
Message 8 of 17
(7,914 Views)
Yes, but all the arguments are already available...
So: DAQmxRegisterDoneEvent will internally call the callback function DoneCallback with all its arguments, i.e., it will call
DoneCallback (taskHandle, status, callbackData); those arguments are known to DAQmxRegisterDoneEvent because, for example, the taskhandle is the first parameter to DAQmxRegisterDoneEvent...
Message 9 of 17
(7,910 Views)
so the declaration of DoneCallback() also specifies its arguments?
Message 10 of 17
(7,908 Views)
