LabWindows/CVI
Continuous Pulse Train with PCI-6602
I was wondering if there is a way to generate a continuous pulse train using one counter on the PCI-6602. If so, how would I go about doing it. I tried using the ND_PULSE_TRAIN_GNR, but that only produced an instantaneous pulse. How would I get it to be continuous?
(3,259 Views)
I figured it out. I just used ND_RETRIG_PULSE_GNR and used the other counter as a trigger.
(3,259 Views)
Dschless,
The TIOgenSquareWave.C example demonstrates how to generate a continuous pulse train with the PCI-6602. It is available in the following location:
C:\Program Files\National Instruments\NI-DAQ\Examples\VisualC\Ctr
Good luck with your application.
Spencer S.
(3,259 Views)
thanks
(3,259 Views)
