LabWindows/CVI
Conversion from either RGB or HSL to Grayscale color spaces
Is there an NIVision function that allows easy and fast conversion from either RGB or HSL images into grayscale images ? I know that I can directly manipulate each pixel to get a grayscale image, but want to know if there is a faster way by using NIVision-only functions. Thanks !
(4,561 Views)
I would recommend extracting the Luminance plane using the IMAQ ExtractSingleColorPlane.vi - this gives the best greyscale representation from a color image.
(4,551 Views)
Sorry - didn't realize you were using CVI:
The CVI function is:  imaqExtractColorPlanes
The 'IMAQ Vision for LabWindows/CVI Function Reference Help' will detail the usage of this function
https://www.ni.com/docs/en-US/bundle/322567a/resource/322567a.pdf
(4,550 Views)
Ok. I understand what you are saying, and makes a lot of sense. Thanks a lot !
(4,547 Views)
