LabWindows/CVI
Conversion of an Instrument Driver from LabWindows/CVI to LabVIEW
hi,
I am using Labview 2012 and NI Labwindows CVI 2013. I am trying to do https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x25QCAQ&l=en-US, however the CVI 2013 is slightly different and I am struck at the 3rd step described here, since the Create release feature does not exist.
Do anyone have any experience with such issue? I guess it must be something dead easy, yet I'm stuck in there 🙂
Many thanks,
Kentmey
Kentmey
(4,422 Views)
Hey Kentmey,
You should be able to click Build > Configuration > Release, which sets the current build mode to be a Release file (as opposed to a debug version). Then if you click Build > Build, it will perform the same action as the "Create Release Dynamic Link Library" setting mentioned in the tutorial.
Hope that helps, and let us know if you run into any more trouble with it!
(4,414 Views)
Hi Daniel,
I consistently get the same error message, as attached. Is it an issue you would say?
Many thanks,
Kentmey
(4,394 Views)
