LabWindows/CVI
Convert VARIANT to char (String)
i will convert a String out a VARIANT from an AxtiveX-Objekt into a Char[256].
The value in the VARIANT is "234566;123321;344343;995867;".
That a funktion need i to do this.
(6,616 Views)
From CVI's  ActiveX library:
Converts the BSTR string in the variant you specify into a dynamically allocated C-style string.
On success, CA_VariantGetCString releases the contents of the variant and marks it as empty.
CA_VariantGetCString returns an error if the variant does not contain a BSTR value.
When you no longer need the C-style string, call CA_FreeMemory to free it.
Prototype
HRESULT CA_VariantGetCString (VARIANT *Variant, char **Value);
(6,613 Views)
