LabWindows/CVI
Convert uint8 hex array in reverse order to double/uint16/string/etc
I'm retrieving a size 4 uint8 array from a buffer that arrives like the following:
c4 ed e5 d7    (hex format)
and need to convert it so it reads:
d7e5edc4 (hex)
3622170052   (decimal format)
I know it can be done in a loop using some <<'s or something.  I can't remember all this low level stuff so help would be greatly appreciated.  I can rearrange the initial data array, but not sure how to convert to decimal number.  I assume a simple for loop starting at the end would be the easiest way to solve.
PS on this subject, where is a good place that explains all the uses of << or >> or ^= etc
(12,016 Views)
Accepted by topic author ngay528
I happened to use this routine in the past to accomplish a task like yours:
unsigned char   string[5];
int  number;
string[0] = 0xc4;
string[1] = 0xed;
string[2] = 0xe5;
string[3] = 0xd7;
string[4] = 0x0;    // string terminator
number = conv_dword_to_int (string);
int conv_dword_to_int (unsigned char * buf)
 return ((*(buf + 3)) << 24)  +
   ((*(buf + 2)) << 16)  +
   ((*(buf + 1)) << 😎 +
   (*(buf + 0));
(12,002 Views)
An alternative approach is to use unions:
typedef union {
    int i;
    char b [4];
} unionInt;
int EndianInt (int *in, int *out) {
    unionInt ui, uo;
    ui.i = *in;             // Start by copying the integer value
    uo.b [3] = ui.b [0];    // Just swap the bytes over
    uo.b [2] = ui.b [1];
    uo.b [1] = ui.b [2];
    uo.b [0] = ui.b [3];
    return *out = uo.i;     // Allows in and out to point to the same data, if required
To process an array of bytes, simply cast it at the point of call:
    char dat [] = {0xc4, 0xed, 0xe5, 0xd7};
    int value;
    EndianInt ((int *) dat, &value);
JR
(11,985 Views)
There is already a function for this (can be used for that purpose) in ANSI C library.
It is memcpy ! 🙂
Copy this into Interactive Execution and run:
#include <ansi_c.h>
static unsigned char string[5];
static unsigned int  number;
string[0] = 0xc4;
string[1] = 0xed;
string[2] = 0xe5;
string[3] = 0xd7;
memcpy (&number, string, 4);
printf ("0x%04x\n", number);
S. Eren BALCI
IMESTEK
(11,951 Views)
That trick only works on little-endian processors. Admittedly that accounts for the vast majority of (Intel) CPUs out there, but some of us work with big-endian ones as well and we have to be careful when using a mix of the two types in any system.
Mike
(11,917 Views)
