LabWindows/CVI
Convert value
Is there a way to convert a double  example 900000000000000000000000000000000000009, which is 9.0 E+37 to scientific notation?
I am trying to compare values received from a DAQ to limits that I have.
Thanks!
(3,592 Views)
Hello FredTest,
Yes it is possible. Just try the following code that uses "Formatting functions" and 'Modifiers" (more details in these two help sections)
double NumericValue=456.675;
char ConvertedValue[30];
// Eventually get value from a control or anything else
Fmt(ConvertedValue, "%s<%f[e2]", NumericValue);
// Display Converted value in text box, text string ...
Hope this helps you going on on your project
(3,573 Views)
