LabWindows/CVI
Converting data acquired from byteRead=inp(DATA)
Hi, I have acquired data from parallel port DATA register and would like to know what type of data format is byteRead? In the program, I've defined byteRead as a char and I need to convert byteRead so that I can perform an arthimetric operation (divided it by 256) to obtain a decimal answer.
I've tried Fmt (decimalRead1, "%s<%d", byteRead1); declaring decimalRead1 as a char or int but the error message is it expects a pointer to void.
Can someone help? Thanks.
(2,883 Views)
Put a & in front of decimalRead1. It's an output, therefore, passed by reference.
Best Regards,
Chris Matthews
(2,883 Views)
