05-11-2006 10:13 AM
05-11-2006 12:10 PM
I could not duplicate this.
I used the line below to make a copy and the file copied correctly.
CopyFile("Passwords.new.txt", "Tempjunk.del");
The file was in its enitirety and the new filename was correct.
How are you trying to use it? What exactly are you referring to that got truncated? The file Name?
05-12-2006 12:12 AM
05-12-2006 02:38 PM
Hi gruvee,
I'm glad that there is a satisfactory workaround! Just so you know, this problem was identified and reported to R&D. It has been fixed in CVI 8.0. I am assuming you are using 7.1 or previous so please let me know if you are using 8.0 and are still seeing this behavior 🙂
Thanks for letting us know about the problem.
Megan B.
