LabWindows/CVI
Correct example for ibnotify for CVI?
Is there a working example of the use of the ibnotify and and the asynchronous call back that works with CVI 9.01?
Some of the examples use void others use int, and the nmbe of parameters and thier types is variable also.
It seems that the examples have not been updated to be accurate.
The examples do not compile......
(3,263 Views)
Fred,
Are you getting errors when implementing ibnotify?  Also what examples do not compile? They should all be located under C:\Documents and Settings\All Users\Documents\National Instruments\CVI90 , while i haven't run every one of them, they should all work out of the box. Make sure that you haven't saved over one of the examples. I always make a backup folder and copy all of my examples just incase. If you think you did write over one, you can re-install all examples by inserting your CVI disk and re-installing the package.
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(3,237 Views)
