LabWindows/CVI
Corresponding PFI line
Concerning the example ContWriteDigChan-Burst, Introductions for running, no.6
"6. Specify the handshaking parameters. The Ready for Transfer Event will be asserted any time this device is ready to transfer data. The Pause Trigger Polarity tells this device when to pause. If the polarity is set to High, then the device will pause when the corresponding PFI line is high."
Which corresponding PFI line belongs to each of the two handshake signals "Ready for Transfer" and "Pause"?
(4,736 Views)
what's the hardware, you are using?
Frank
(4,710 Views)
Hi Frank,
we are using a PCIe 6537card. We want to set up a pattern generator, 16 bit data and clk. The clk signal is available and the output line adjustable in the application. But we get no data and a time out.
Ralph
(4,705 Views)
Hi Ralph,
do you get an explicit error message and if so, could you attach it here?
Frank
(4,701 Views)
Hi Frank,
yes, attached I have the screenshot.
(4,683 Views)
the corresponding PFI lines are statet here:
http://digital.ni.com/public.nsf/allkb/39F8242E2553F63E86256FE3007BF69F
Frank
(4,564 Views)
