LabWindows/CVI
Could you give me an InstallCallback testing sample?
I am trying to test how to use the InstallCallback but I couldn't succeed.
Please give me an sample program for testing the InstallCallback function.
Thank in advance.
Heedone Jang
(2,904 Views)
Try with this example: with a simple switch I select and install two different callbacks with different callbackData for a command button.
When the command button is pressed a message displays the callback name and the callbackData received.
Roberto
(2,904 Views)
