LabWindows/CVI
Couldn't open port com
HI,
     I am using LabVIEW 8.6 to control an pump through USB (computer) to RS-232 adaptor (pump) using COM 4. The first time the VI runs fine. But After I quit the VI, and restart the VI. I can not access the same COM 4. Did I miss anything in closing the com port or in the initiation the com port. My VI is attached.
(3,467 Views)
You should post your question on the LabView board; this one is for LabWindow/CVI discussions.
JR
(3,465 Views)
Hey RyanWu,
When you navigate to MAX, does the COM port show up with a yellow exclamation mark next to it? If it does, then please read this article on how to fix this problem.
Thank you,
Ryan
(3,416 Views)
