LabWindows/CVI
Counter source for semi period measurement
I'm quite new to DAQmx in CVI, and I've got a problem with counters programming.
I use an USB6259 board and CVI 8.0.
I use the DAQmxCreateCISemiPeriodChan function to create a task to measure semi periods. I would like to connect an external signal to the counter source, but then I've got this error :
 NON-FATAL RUN-TIME ERROR:   "BuffSemi-Period-Finite.c", line 157, col 9, thread id 0x00000AB8:   Function DAQmxStartTask: (return value == -89137 [0xfffea3cf]). Specified route cannot be satisfied, because it requires resources that are currently in use by another route. Property: DAQmx_CI_CtrTimebaseActiveEdge Source Device: Dev1 Source Terminal: 80MHzTimebase Destination Device: Dev1 Destination Terminal: Ctr0Source  Required Resources in Use by Source Device: Dev1 Source Terminal: PFI1 Destination Device: Dev1 Destination Terminal: Ctr0Source  Task Name: _unnamedTask<0>  Status Code: -89137
Here is my code :
  // DAQmx Configure Code
  SetWaitCursor(1);
  DAQmxErrChk (DAQmxDisconnectTerms ("/Dev1/80MHzTimebase", "/Dev1/Ctr0Source"));
  DAQmxErrChk (DAQmxConnectTerms ("/Dev1/PFI1", "/Dev1/Ctr0Source", DAQmx_Val_DoNotInvertPolarity));
  DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
  DAQmxErrChk (DAQmxCreateCISemiPeriodChan(taskHandle,chan,"",min,max,DAQmx_Val_Ticks,""));
  //DAQmxErrChk (DAQmxCfgImplicitTiming(taskHandle,DAQmx_Val_FiniteSamps,samplesToRead));
  // DAQmx Start Code
  DAQmxErrChk (DAQmxStartTask(taskHandle));
Is it possible to assign an external signal to counter source when using this function ?
Thank you.
(3,214 Views)
Here there is the description of your error:
Regards.
(3,187 Views)
