LabWindows/CVI
Counting program does not work well
I'm trying optical measurement using avalanche photodiode (APD).
I created counting task on MAX and confirmed the task counted the pulse edge from APD correctly (i.e. if the signal is 1 MHz, the count value increased 1,000,000 /s).
However, when the task loaded to my CVI program, the task does not return the expected count value.
My program is like this:
qw=0.;
GetCtrlVal (pnl_panelHandle, PNL_GATEFREQ, &gatetime);			//gate time is read from the UI panel in ms.
timeout = gatetime/1000 ;						//convert gatetime from ms to s.
DAQmxLoadTask ("CI0_TaskHandle", &CI0_TaskHandle);			//load the MAX task.
DAQmxStartTask (CI0_TaskHandle);					//start the task.
DAQmxReadCounterScalarF64 (CI0_TaskHandle,timeout, &qw, NULL);	    //read count value and pass it to qw.
Delay(timeout*1.2);
DAQmxStopTask (CI0_TaskHandle);						//stop the task.
return qw;
in the program, this counting is repeated.
This program returns very low qw value. For example, even if gate time is 1000 ms (thus timeout is 1 s), most of qw is 0 or 1.
When the bright light is irradiated to APD, qw value increases to ~30. So the program is working, but the maximum value is too low.
Is there any problem in my program? I'm not sure about it...
(2,889 Views)
Accepted by topic author atkjmb
You are reading the count immediately after starting the task. I think you should put the delay before the read. Timeout value in the read function is not a gate. It is the maximum duration the function is going to wait for reading. It does not guarantee a waiting duration of 1.2 sec.
Is the task working as expected when you run it from MAX?
S. Eren BALCI
IMESTEK
(2,872 Views)
The program worked when putting delay function before the read function. I misunderstood about the read timing.
Thank you very much!
(2,855 Views)
Nice, glad it worked. Please don't forget to mark my post as acceptable solution. Some other person might also benefit. Cheers..
S. Eren BALCI
IMESTEK
(2,851 Views)
