LabWindows/CVI
Crash when debugging under CVI 5.5 and initialized DAQ board
I have experienced that if I terminate a program with Ctrl+F12 (from the
source window), and later on restart the same application (run) the PC
crashes.
If I compile, run, terminate, restart the same project under CVI 5.0.
Everything works OK !!!
I am working with a 6602 card, and the fault only happends if I have been
"talking" to the daq board.
Has anyone seen the same ? and/or can anyone give me a hint or an advise.
Finn Olesen
(3,237 Views)
Hi Finn
Finn Falentin Olesen schrieb in im Newsbeitrag:
3a7fdf7a@newsgroups.ni.com...
> Hi,
> crashes.
Yes, I have exactly the same effect here. Windows 98 hangs completly, when a
program is terminated in the CVI debugger and when the program uses any
NIDAQ call.
I allways thought (until now) that this was a problem wit
h my multi
threading, although I did not find an error...
Stephan
(3,237 Views)
Hi Finn,
Yes, I have seen the same thing. I don't have a solution, but I do
have a work around. Bring up the function panel for DAQ_Clear()
and run the function. This will let you restart your program without
crashing. Of course, you will probably not be able to continue
execution.
You might try calling DAQ_Clear() at the start of your program.
Hope this helps.
Reed.
Reed Blake
Beta Technology
Industrial and Scientific Computing
Finn Falentin Olesen wrote in message <3a7fdf7a@newsgroups.ni.com>...
>Hi,
>crashes.
>Thanks
>Finn Olesen
(3,237 Views)
I have exactly the same problem as you. Each time i stop my program with CTRL+F12 after a call to a NI-DAQ function and i try to start a new execution, Windows 95 (or 98) crashes.
I find no soultion to this problem.
Do you find one ?
Thanks.
(3,237 Views)
