LabWindows/CVI
Create DIAdem data file failed without errors
I tried to create *.tdms file format with following codes.  It did not create file and did not return any error codes.  I could not find the problem. Would anyone let me know what the error was?
#define TDMS_FILE_TIT "Test 200 Hz TDMS data format"
#define TDMS_FILE_AUT "No Joen"
#define TDMS_ORION_200_HZ_CHANS 44
#define NUM_MAX_POINTS 44
// Types
// Static global variables
static const char * GROUP_NAME = "200 Hz data";
static const char * GROUP_DESC = "Test 200 Hz data collect by simulation test";
// Static functions
// Global variables
double startTime, elapsedTime;
TDMSFileHandle hTdmsTestFileHandle;
TDMSChannelGroupHandle hTdmsTestGroupHandle;
TDMSChannelHandle * phChannels;
// Global functions
/// HIFN The main entry-point function.
/// HIPAR argc/The number of command-line arguments.
/// HIPAR argc/This number includes the name of the command-line tool.
/// HIPAR argv/An array of command-line arguments.
/// HIPAR argv/Element 0 contains the name of the command-line tool.
/// HIRET Returns 0 if successful.
int main (int argc, char *argv[])
int tdmsError = 0;
int i = 0;
unsigned int usChan;
char szChanName[50];
char szChanDesc[50];
tdmsError = TDMS_CreateFile(TDMS_FILE_PATH, TDMS_Streaming, TDMS_FILENAME,
TDMS_FILE_DESC, TDMS_FILE_TIT, TDMS_FILE_AUT, &hTdmsTestFileHandle);
tdmsError = TDMS_AddChannelGroup (hTdmsTestFileHandle, GROUP_NAME, GROUP_DESC, &hTdmsTestGroupHandle);
phChannels = malloc (sizeof(TDMSChannelHandle) * TDMS_ORION_200_HZ_CHANS);
for (usChan = 0; usChan < TDMS_ORION_200_HZ_CHANS; usChan++)
sprintf (szChanName, "point_%d", usChan);
sprintf (szChanDesc, "Data for channel %d", usChan);
tdmsError = TDMS_AddChannel (hTdmsTestGroupHandle, TDMS_Double, szChanName, szChanDesc, 0, &phChannels[usChan]);
free (phChannels);
tdmsError = TDMS_CloseFile (hTdmsTestFileHandle);
return 0;
(3,825 Views)
Found the problem. Resolved.
Thanks.
(3,821 Views)
Hi NICoder,
If you could, please post and mark your solutions when you find them for anyone who happens to stumble upon the thread in the future Smiley Happy
Cheers,
KyleP
(3,807 Views)
The above code did not have data section therefore the NI API did not created the TDMS file.  It worked when I added data.
(3,796 Views)
