LabWindows/CVI
Create ODBC Database DSN Dynamically
Robert,
Add this statement to the code and see if it works, this contains the location.  Obviously MyDir and MyDatabase.mdb should fit to your parameters.
RegWriteString (REGKEY_HKLM,
 DatabaseKey,
 "DBQ", //The Location,
"C:\\MyDir\\MyDatabase.mdb"); //location of the database on the machine
-Dave
Message 11 of 13
(2,093 Views)
I would try it tomorrow to see how it works.
Robert
Message 12 of 13
(2,086 Views)
For me, the easiest has been to create a myconnection.dsn file using the ODBC administrator control panel.
Then, in your executable distribution, include the myconnection.dsn file, and stick it in C:\Program Files\Common Files\ODBC\Data Sources
Then, you can use the following connect string : "filedsn= myconnection.dsn;UID=userid;PWD=password", and it works like a charm, both in LabVIEW and LabWIndows
in addition, because the DSN is in a standard location, other application, such as Excel can use it just as easy.
Message 13 of 13
(1,825 Views)
