LabWindows/CVI
Create a generic list in .NET wrapper
I have an issue that is similar to this one.
I use a device driver written in .NEW.
I've already created the .NET Controller (wrapper) and I'm able to use a lot of the functions from the wrapper.
Some of tjhe functions have a parameter that is a generic list with a special data type (System_Collections_Generic_List_T1).
I don't know how to create a list of this type.
In the thread I linked at the beginning of this topic I see that a function called
System_Collections_Generic_List_T1__Create_2( ...)
is referenced, but I don't find this function, neither in the driver .h file, nor in the mscorlib .h file.
Where is that function?
(I use CVI 2015 SP1)
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(467 Views)
I mean, I don't find it in the mscorlib (.h - .c - .fp) available in the supplied CVI samples/dotnet folder.
Should I use mscorlib2 (.h - .c - .fp) in the same folder?
Or should I generate a mscorlib4 wrapper by myself?
Vix
Using LV from 7
(418 Views)
