LabWindows/CVI
Create a path for distribution kid
I have created a application and now I want to build a distribution kid. Here I got a problem. My application needs a *.txt data to run. In my development code I save the data in the same folder as my *.uir and the *.c files (as example: fopen("Test.txt", "w");)So now is my question how can I say in my program that it should create the *.txt file in the same folder where my program gets installed over the distribution kid?
My first idea would be to call the whole path where the program gets installed (C:\Program\MyApplication\Test.txt).
But here I don't know where the program gets exactly installed on another computer. Is there a way to find that out?
Best regards
(3,529 Views)
Accepted by topic author Fasching_K
You want GetProjectDir() from the utility library.
However, beware that your app may not have write access there. If you need to write data to a file from your app, see here.
(3,493 Views)
