LabWindows/CVI
Create directory
Hi
I want to create a new folder if it does not exist with labwindows 3.1. How can I do that?
Tanks
(3,872 Views)
Sir,
I double checked in the old LabWindows manual to make sure we had this function, and it seems we did have it back then. I think you want the MakeDir() function. The input is the new directory name. The return value is the result of the operation. An example would be making a directory named \Data\Waveform on drive C assuming C:\Data already exists. This would be for a C compiler as well:
result = MakeDir ("C:\\Data\\Waveform");
Daniel McChane
Application Engineer
(3,872 Views)
Tanks a lot for your answer, you help me a lot
David
(3,872 Views)
Good to hear. Good luck on the project.
Daniel McChane
(3,872 Views)
