LabWindows/CVI
Create dll for use in Labview
Hi guys,
Basically I have got the library file (.c & .h) which the main.c. will be using.
How can i create a dll file from Labwindows 2013 that can be use in Labview?
Thanks.
(7,714 Views)
Hello adriano08!
Yes, it's possible to create LabWindows/CVI DLL and call it from LabVIEW, using the Call Library Node.
Here are some references for you to start:
Best regards!
- Johannes
(7,700 Views)
Haven't done it for a while but putting your code into a Function Panel and creating a DLL is a very simply way forward. The Function Panel can then be imported directly into LabVIEW. You would have to investigate how this is all done as it has changed since I last did it.
Kevin
(7,689 Views)
