LabWindows/CVI
Create help function for application
Hi, I would like to creat help function for user in my aplication, where i using images like buttons and indicators. My idea is that, after i click or move the cursor on some of these object it shown me little yellow window whit description, or open window like windows help. i am begginer and i don't not where i shoud start, i will be glad for any advice. i spend many hours googling but i cant find anything reasonable, so thank you for any suggest. Here is screen for better idea
(4,583 Views)
(4,563 Views)
Accepted by topic author racek24
One possibility is to add appropriate tooltips to controls on the UI. A tooltip is a small balloon that appears when you hover over the control for a while.
Tooltips can be added in the UIR editor:
Alternatively they can be added programmatically with
SetCtrlAttribute (panelHandle, controlID, ATTR_TOOLTIP_TEXT, "Sample tooltip");
In both cases you are limited to single- or multiline texts; if you want to add some graphical element you should create your own panel and display it. You should add a timer to discard the panel after a few seconds. If you load the panel as a child of the original one you may customize "tooltip" appearance, e.g. hide the titlebar and set an outline border.
(4,547 Views)
Thank you very much, this is exactly what i looking for.
(4,499 Views)
