LabWindows/CVI
Create text Report ?
Hi
how can i create a nicely formatted report with out using excel or word?
I need a way to display to the user in a formatted way, Like Bold text with underlining different font sizes, How can i do this?
Help share your knowlegde
(4,129 Views)
Hi Shako,
reporting in CVI has always been a challenge. First of all take a look at this old discussion that unfortunately had no follow up.
When planning for reporting in a CVI application at present I can think to those different instruments:
  • A text-only report, generated by creating appropriate lines of text and calling PrintTextBuffer; very olod fashioned, only personalization possible is text and column spacing; the report can be saved as-is and printed later
  • Creating a dummy panel where to put text to be printed and send to printer via PrintPanel; very large possibilities of personalization: the panel acts as a template, using listboxes or text controls you can adapt the report to your needs; possibility to embed graphs and images (logos and so on); preview possible, limited possibilities to save reports (one image file per page)
  • Use NI Report Generation instrument driver (nireport .fp) that ships with CVI: very large possibilities of personalization; no preview possible nor saving report facility; look at the samples in samples\reportgen folder
  • Use Excel or Word reporting; large possibilities of personalization but those programs must be installed in the system together with CVI application; operating on MS programs via ActiveX is not the easiest beast to manage but it can be done
  • Use a PDF virtual printer that can be managed to produce multi-page reports; this argument has been discussed here and here
I have personally used the PrintPanel way a lot until we moved to Haru PDF library to produce native PDFs
(4,123 Views)
Its nice to hear that a reporting is in the piplines.
None of the solution are ideal.
NIReport would be great if i could preview it.
The Panel option was my last resort,To add controller dynamically is a pain.
I cant use word or excel because the user would have to have it installed on there pc and alot of them dont using word or excel.
Is there a way to display PDF's in a CVI panel?
(4,120 Views)
Could you please attach an example for using Haru PDF?
I got another application which Haru PDF would be great.
(4,117 Views)
I have added a sample project using this library to the Developer Zone Community: you can find it here. Feel free to ask or comment about it.
(4,101 Views)
