LabWindows/CVI
Creating CSV file according with the international settings
Smiley Happy I am glad it's not only me...
I just tried it with the following result:
    GetLocaleInfoEx (LOCALE_NAME_USER_DEFAULT, LOCALE_SLIST, (LPWSTR)msg, 8);
    DebugPrintf ("List separator: %s\n", msg);
in my source code works as expected, provided I add the compiler defne (VISTA or newer)
However, in the interactive execution, with the same compiler define, the following code
#include <windows.h>
    static char    msg[8];
gives an error:
Interactive Execution - 1 error, 1 warning
 5, 62    warning: cast from 'char *' to 'LPWSTR' (aka 'unsigned short *') increases required alignment from 1 to 2
 1, 1   error: Unresolved symbol: GetLocaleInfoEx
.... ah yes, and a question / suggestion... why is /DWINVER=_WIN32_WINNT_WIN7 not added by default - CVI2015 does not support Windows XP and VISTA anymore....?
Message 11 of 14
(2,529 Views)
My apologies for not having actually tested this before posting. I too was able to reproduce this linker error and, unlike the missing prototype compiler error, this one does seem to be related to the interactive window.
As best I can tell, you're running into a form of this issue. I can't explain why this happens for some SDK functions, but not for others -- even for functions that are also in kernel32.lib (e.g. LoadLibrary).
Wolfgang: I had forgotten that CVI 2015 no longer supports XP. You are correct. The default value of WINVER should not have been _WIN32_WINNT_WINXP. I've written CAR 544425 to address this.
Roberto: the macros are per-project (and per-build configuration!). You can look through this topic if you're ever unsure of the scope of some option in CVI.
Message 12 of 14
(2,512 Views)
Thank you for this list, I wasn't aware of this useful compilation.
Message 13 of 14
(2,500 Views)
That's indeed very useful: thank you for taking it to my attention! I'll save that page in my favourites.
Message 14 of 14
(2,493 Views)
