LabWindows/CVI
Creating File Based on TimeStr and DateStr
Hello
I am trying to set up an automatic new log file opening sequence in my program using DateStr and TimeStr as follows:
char gLogPath[MAX_PATHNAME_LEN];
int handleLogFile;
Fmt(gLogPath,"C:\\RunData\\MTB_RUN%s%s.txt",DateStr(),TimeStr());
RemoveFileIfExists (gLogPath);
handleLogFile = OpenFile (gLogPath, VAL_WRITE_ONLY, VAL_TRUNCATE, VAL_ASCII); // Create it
The program errors out saying that there is a "bad file handle". If I had only a single '\' in my file path then I receive a warning saying that there are bad characters \R and \M in my file path, so I converted these two to '\\'. Can someone please suggest where I am going wrong here?
Ajit
(3,982 Views)
The cause of the error can be in the result of DateStr () and TimStr (), depending on date and time separators as defind in control panel: as an example, my locale uses slashes as date separators and colons as time separators, both of them illegal inside a filename...
If this is your case, you could for example design a function that scans the string and substitutes those characters with hyphens or underscores.
(3,974 Views)
