LabWindows/CVI
Creating Matlab mat files ?
Hello all,
I know it's possible to communicate between CVI and Matlab through some
ActiveX or somesuch, but it's not really what I'm curious about.
Is there some library/toolkit that allows me to save data directly in Mat
files, so they can be deserialized and used directly by a Matlab program
later on ? I don't want to reverse engineer the Matlab format !
Sending the data to Matlab and asking it to save it on its own is not really
an option as I'm using CVI on Linux to produce the data.
Guillaume Dargaud
http://www.gdargaud.net/
"Although it is said that faith can move mountains, experience has shown
that dynamite works better."
(4,866 Views)
You could look at the 'matio' open source project here.
Alternatively, the MAT file format is published (in PDF format) here.
Martin
Certified CVI Developer
(4,854 Views)
hello guillaume,
did you get a solution for that problem? i need the same solution. values from labwindows/cvi should be saved in a matlab file.
thanks for help.
(4,599 Views)
Hi cmos2k11,
Unfortunately, CVI does not natively provide the desired functionality.
Nestor
(4,560 Views)
