LabWindows/CVI
Creating a Text File to store data
Hi:
I'm looking to get values from numeric boxes using GetCtrlVal() and then store those values in a created file.
I know I need to use:
FILE *variable, sprintf(), and fopen() but I'm not quite sure how it is all integrated.
Any help is appreciated...thank you.
(3,425 Views)
An alternative approach to fopen and so is the use of Formatting and I/O library functions. You can look at samples\app\atedemo.prj example that uses OpenFile and WriteFile functions to store test results collected from an automated test equipment software.
The online help for file I/O functions is quite explicative and should be enough for you to understand function usage in the sample project and so starting your coding.
(3,421 Views)
