LabWindows/CVI
Creating a filter using dup, dup2 and pipe in CVI
In Visual C++, and on Linux and Unix it is possible to use the pipe concept to use an existing program as a filter or data source from within you program by using the functions dup, dup2, spawn or exec and pipe.
Basically, you create a pipe, replace stdout with the write side of the pipe, spawn the desired program, for instance " cmd /c dir", and then read the read end of the pipe to capture the result.
On the latest versions of Visual C++ these have been deprecated and I have used the replacement _dup, _dup2, _spawn and _pipe to accomplish this.
However, I can not find the equvalent in CVI. I can't even find the header files io.h, fcntl.h or process.h.
Is it possible to use this type of approach using CVI?
If so, How?
(3,376 Views)
Hi, klotz,
LabWindows is an ANSI C compiler. Are those functions mentioned by you ANSI C functions? If not, then you cannot use them directly in CVI. If you can use them in C++, your best bet would be to create a C++ DLL and use it in LabWindows. This pagehas some good info on using DLL in CVI.
Song Du
Systems Software
National Instruments R&D
(3,340 Views)
