LabWindows/CVI
Creating a function panel in CVI
Hello guys,
I tried to create a Function Panel in CVI. There is a USB card attached to the device and it will transmit a card reference value to the code. That reference value as to pass every function in a function panel for the code to determine the next task.
But C file of the Function panel is not transmitting the reference value since each function works individually. So, I tried to save that reference value in the main source code and transmit it to function panel c code but then it created a run-time error called "General Protection fault at 0x5E34C005".
Is there a way to solve this problem?
(1,586 Views)
Dear  Anbarasan.10 ,
Can you please attach the cvi file?
(1,400 Views)
