LabWindows/CVI
Creating a graph on .uir labwindowscvi 2017
Hello I would like to create a graph and pass in parameter y values that change(effort as a histogram to see if I reach a maximum effort that I defined) and x fixed values time if you have examples to propose thank you i'm new in the labwindows
thks for help
Message 1 of 8
(3,800 Views)
I think a good starting point if you are new to CVI is to use the menu Help / Find Examples and the search keyword "graphs". This search will yield many examples, e.g., graphs.cws that demonstrate how to use graphs.
Message 2 of 8
(3,794 Views)
Hello
thks for replaying , now i create this interface that can :
acquire image read the caracter (number ) using ocr
after that i display a graph its an histogram who affiche number on object ans effort applying in each objetc
but i have probleme with the displaying on bare on right (plot 1 plot2 ......) its debord and i want to stop it on each plot and to synchronise without displayin all  the plot
view the pic bellow
thks for helping
Message 3 of 8
(3,766 Views)
Hi, I had a look at your picture - but I do not understand your text below...
its debord
...what do you want to display and stop?
@Bylka wrote:after that i display a graph its an histogram who affiche number on object ans effort applying in each objetc
Message 4 of 8
(3,762 Views)
thank you for answering I did not express myself well
in the right bar where I circled in blue the histogram takes data from an array and then on the bar or is written plot ..... does not stop it displays and overflows I would like to disable it
Message 5 of 8
(3,760 Views)
so you are talking about the graph legend?
if so, why does the legend show 24 green plots, the histogram only 6? Could it be that you add a new plot for every data point instead of replacing the old plot (delete and plot again)? Still, I am afraid that I did not really understand your issue...
Message 6 of 8
(3,756 Views)
Because on x axis it show number of stud (bolt) after that we apply an effort so the histogramme take a defferent values of array on each bolt it s why the legend of plot change and on graphe its steel fixed by user numgoujonValue 6 or 4 ..;
Message 7 of 8
(3,750 Views)
i found how to disable it
now i have other problem on my code can you help me on it i have to make some change on it
thks
Message 8 of 8
(3,747 Views)
