LabWindows/CVI
Creating and using compiler defines
I'm having trouble doing this successfully. Can anyone tell me what I'm
doing wrong?
I'm running LabWindows/CVI 5.0 under WinNT 4.0. I have it installed for
compatibility with Visual C/C++.
In my code, I have
#ifdef MY_DEF
#else
#endif
I want stmt-a to be run but not stmt-b, so I tried to define MY_DEF. In
the project window, under menu option Options|Compiler Defines, I now
have:
/MY_DEF=1 /DWIN32_LEAN_AND_MEAN
But when I run the project, stmt-b gets run but not stmt-a.
Then I tried:
#ifdef MY_DEF
#endif
#ifndef MY_DEF
#endif
And again stmt-b gets run but not stmt-a.
TIA for any help.
B
ande at san dot rr dot com
(5,409 Views)
BA wrote:
> In my code, I have
> #ifdef MY_DEF
> #else
> #endif
I thought that somewhere (like in a .h file) you had to to
#define MY_DEF 1
Been a long time since I did C but it is worth a try.
Kevin Kent
(5,409 Views)
Hi Ande,
You need the D after the /. Options|Compiler Defines should be
/DMY_DEF=1 /DWIN32_LEAN_AND_MEAN
For your purposes, the =1 is optional.
Reed.
BA wrote in message <382720B9.94FF2463@san.rr.com>...
>doing wrong?
>have:
>TIA for any help.
>B
(5,409 Views)
