LabWindows/CVI
Creating installation versions of applications
Can I make installation versions of my apps designed in
evaluation version of LabWindows/CVI ?
I've created one [with inno setup 2], but when I run installed
application there was a notice that evaluation has expired.
I want to create these versions for _educational purposes_ only.
___________
regards
Frog
(3,348 Views)
No, the demonstration version of LabWindows/CVI will only create applications that will run for a few minutes before giving you the expiration message. I believe it is 5 minutes that it will run before displaying the message.
Best Regards,
Chris Matthews
(3,348 Views)
before
It's 10 minutes. But that's not what I meant. After installing and
running application I got notice 'Evaluation Expired'. 10 minutes is
enough for me to present the application, but I want it just to run.
___________
regards
Frog
(3,348 Views)
Oh, sorry, I misunderstood. Yes, the eval software does expire after time. If you request a new CD via the web and use it instead, it will not expire for quite a while.
Chris
(3,348 Views)
after
will
> Chris
No, I should be sorry for my bad english 🙂
I know that evaluation software expires after time, that's not what I
meant either.
I made stand-alone executable with LabWindows/CVI 6.0 then I created
installation version (exe + needed libraries + ... anything required
to run on another computer). The problem is: when I install my program
on someone elses computer and trying to run it, there's a notice
'evaluation expired'
I emphasize once again that I don't want to distibute any software
created with eval version of your software (I want to enclos
e the
program to thesis as an example of multithreading in CVI). Beside
there's mentioned earlier 10 minut limit so the app couldn't be used
for commercial purposes.
Thanks in advance.
___________
best regards
Frog
(3,348 Views)
