LabWindows/CVI
Creation of DLL
I am trying to create DLL of peakest.cws on fft floder of examples. Can anyone help with this
(3,708 Views)
Hello Sammadhu,
Welcome to the forums.
I'm not sure that I quite understand what you are trying to accomplish. The peakest project is a executable with a user interface, while libraries are not executable programs.
If you want some of the functionality of the peakest program, you can take a look at the source code and either use some of the functions directly or integrate them into a new Dynamic-Link Library project template provided in LabWindows/CVI.
Jacob R. | Applications Engineer | National Instruments
(3,690 Views)
Thanks for your reply
actually I need to create a dll which takes a signal as an input, then plots it and its spectra.Is there any inbult functions to use or how can I proceed with it
(3,593 Views)
You were on the right track in looking at the peakest example. You should be able to use the functions that the example is using from the anaylsis libraries: PlotWaveform, AutoPowerSpectrum, PowerFreqencyEstimate, SpectrumUnitConversion. You can learn more about each of them by opening the respective function panels. Here is a list of the built-in functions avaialble as well.
(3,576 Views)
For to use created DLL in LINUX do I need CVI Run Time Module. If so is there a trail varsion
(3,513 Views)
Hello, since this is a new question, could you please open a new thread. Thank you
(3,501 Views)
