LabWindows/CVI
Ctrl F12 & CVI 5.5
It's impossible to break in debug mode CVI5.5.1 with the sequence
Ctrl+F12.
Could someone please tell me if somebody found a solution ?
(3,298 Views)
The debugger model in CVI has changed from CVI 5.0.1 to 5.5. We now debug
your application as a separate process. Since it is a separate process,
your application's panels will not respond to CVI environment hot keys like
Ctrl-F12. Ctrl-F12 still works, but the active window has to be a CVI window
(project window, source code window) and not your applications user interface
windows. If you do not see the CVI project window, right-click on the CVI
item in the taskbar and select Show Windows. There is a setting in the Options->Run
Options that will hide the CVI windows when your run your application that
you can turn off.
Best Regards,
Chris Matthews
Measurement Studio Support Manager
ode CVI5.5.1 with the sequence>Ctrl+F12.>Could
someone please tell me if somebody found a solution ?>
(3,298 Views)
