LabWindows/CVI
Cursor snap to point in XY graph
I have trouble in LabWindows/CVI 5.0 to have my cursor snap to a point in an
XY- graph, even when I set following attributes:
ATTR_PLOT_SNAPPABLE : TRUE
ATTR_CURSOR_MODE : VAL_SNAP_TO_POINT
Besides, also the attribute
ATTR_ENABLE_ZOOMING seems not to do its job.
Has anyone tried this before?
Kind regards,
Geert Van Doorselaer
(3,178 Views)
Hy Geert,
an
me too.. (see my posting from 02/06/01)
> also the attribute ATTR_ENABLE_ZOOMING seems not to do its job.
Had this problem, too. But in my case it was an user's error:
You have to change the graph input mode to anything else but indicator,
enable zooming and use zooming by Ctrl + left mouse button.
I guess, the data mode has to be retain and if you change the contents of
the original buffer with the data to be plotted, the data has to be copied.
(ATTR_COPY_ORIGINAL_DATA = True)
I got it running, finally... ( I use CVI5.5)
Regards
Harald
Flying:
The knack lies in learning how to throw
yourself at the ground and miss
(The Hitch H
iker's Guide)
mailto:HIlg@gmx.net
(3,178 Views)
