LabWindows/CVI
Custom Scroll Control
Hello again. I'm trying to to create a custom Finger Frienndly scroll bar for tables, tree controlls and single column list boxes. Attached is the one I managed to do so far, but I don't think its nice and tidy, I minimised alot of the stuff that I don't need to minimum size of 1, and I customised the Increment/decrement arrows of an independant control, then replaced the digital display of the normal scroll bar with the one I had custom made.( I got this idea from a posting in this forumbut I can't remember the link now, since LabView doesn't allow to resize the Increment/Decrement part of its digital display.)
If anyone can tidy up or create a new or recreate my controll for multiperpose use (i.e. I can directly resize the whole controll depending on the table/tree size without having to create a totally seperate controll for each one). The way I then use this as a scroll is by making use of the property node of table/tree etc, on the TopLeft Visible option (I think thats what its called 🙂 ). I've tried yesterday for some time, but I can't think of a better way of creating this custom scrolling thing better.
Aditional question. Is there a way of checking if teble/tree etc needs scrolling? This way I can even implement the Disable/Gray property of the custom scroll bar and only use it when its needed.
Thanks in advanced.
Kas
(4,846 Views)
Question already reposted to the LabVIEW board
(4,819 Views)
I know I did. I said that on the message. But the reason I did was because I couldn't move the current post to that board. When I posted the initial message I didn't pay attention to the board that I was posting on :), and the question is nothing related to the current LabWindows/CVI board, hence, I posted a link on the LabView board.
Sorry for messing it up.
Kas
Message Edited by zerotolerance on 03-30-2010 05:45 AM
(4,806 Views)
Anyone ???
(4,780 Views)
Most LabView users do not browse this CVI board, so perhaps your follow-up comments would be better sent to the thread on the LabView board (from where you reference this thread) - this would maximise the probability of a useful reply.
JR
(4,760 Views)
Thanks, looks like the post from the other board started to pick up.
Chears
Kas
(4,747 Views)
